Tagged: 10.2, ensight, fluid-dynamics, post-processing, Visualize Data
May 15, 2023 at 8:33 am
SolutionParticipantSolution 2055427 presents how to display velocity vectors on a uniform cut grid using ANSYS Ensight 19.0. Main point is to use the plane tool of Ensight to control the grid resolution on the clip afterwards. Once the clip plane is created, you can easily change the grid resolution and visualize the resulting vectors. Please see attached document for further details.
1. 2055427.pdf
- Skewness in ANSYS Meshing
