Discovery error: FNE Activation Failed. Peer certificate cannot be authenticated with given CA certificates
May 15, 2023 at 8:33 amSolutionParticipant
Please go through attached document which addresses this FNE activation error while activating Discovery products
1. 2053754.pdf
2. 2053754.zip
- Q: How do I set the license server from my client machine?
- Failover feature ‘Discovery – Level 1’ is not available
- How do I configure RSM to send a solve to a remote machine (no scheduler)?
- Unable to start the Geometry or Mechanical Editor (Linux)
