Tagged: 18.2, General, mechanical, static, structural-and-thermal, structural-mechanics
May 15, 2023 at 8:32 am
Solution
ParticipantPlease refer the attachments to access the solution
1. 2053121.pdf
2. 2053121.zip
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
- ANSYS Mechanical: Fatigue Crack Growth Analysis using SMART Crack Growth
