Tagged: 19, ccl file, cfx, fluid-dynamics, General - CFX, workbench
May 15, 2023 at 8:32 am
SolutionParticipantSometimes it is necessary to load additional solver CCL at runtime. Outside Workbench you can add on the command line by cfx5solve -def name.def -ccl user.ccl or in the Solver Manager by >Define Run->Activate Advanced Solver Controls ->Solver Tab->Solver Arguments: -ccl user.ccl This is not possible within Workbench. The necessary steps are described in the attached pdf document.
1. 2055235.pdf
- Skewness in ANSYS Meshing
