April 13, 2023 at 7:33 amSolutionParticipant
Dimensions in SCDM are linked to an annotation plane. When the plane is hidden, dimensions disappear as well. To hide an annotation plane by keeping the dimensions, we can modify the ‘Outline’ property of the plane and select ‘no outline’. Another method is to asign the plane to another layer and to hide this layer. A demo is in attachment.
1. 2042739.zip
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
- Left-handed faces troubleshooting
