SpaceClaim file has different components. Each component has only single body. Share option is used for all components and for main component. But when one component is slightly rotated, meshing fails. The geometry topology does not change
April 13, 2023 at 7:33 am
SolutionParticipantSometimes when you have different components, sharetopo may fail. This results in updating mesh component. The workaround is to create a single component of all required bodies and use share option for this single component. This way sharetopo and mesh will be successful. Please see attached images. Keywords: Share Topology, SpaceClaim
- Skewness in ANSYS Meshing
