I have a surface body intersecting a solid body such that after share topo it solid body should be splitted into two in meshing. But this does not happen. Why?
April 13, 2023 at 7:32 am
Solution
ParticipantPlease refer to attachment to access the solution. Keywords: overlap, share, topo
1. 2064001.mp4
- Skewness in ANSYS Meshing
