How to define a plane with specified dimensions in CFD-Post and how to use it for plotting contours and streamlines?
April 13, 2023 at 7:32 am
SolutionParticipantPlease refer to the attachments to access the Solution.
1. 909730.pdf
2. define_plane.pdf
- Skewness in ANSYS Meshing
