April 13, 2023 at 7:32 am
SolutionParticipantSometimes when CFD-Post starts, the command black window appears on the screen but the main Display Window does not appear. It can occur when the user changed from a two screen machine to a one screen machine. The main CFD-Post window is on the hidden screen. See the attached document to solve this problematic display.
1. 2063790.pdf
- Skewness in ANSYS Meshing
