ERROR: java exception in com.modelon.oct.modelica.api.NoLicenseException with message: Failed to retrieve license features required for package ‘HeatExchanger’ Feature ‘HeatExchangerLib’ (MLLE Error 3) Failed to check out license ”. No such license exists (FLEXlm Error)
April 13, 2023 at 7:32 am
SolutionParticipantPlease refer to the attachments to access the Solution. Keywords:java modelon
1. 2060577.pdf
- How to avoid the error message “ANSYS Workbench found an error in the value you entered.”
