Discovery Live: In internal fluid flow simulation, how to select multiple inlets/outlets on same face?
April 5, 2023 at 2:33 pm
FAQ
ParticipantCurrently, there is a limitation with the internal flow template, where you can only create one inlet/outlet per capping face. There are a couple of workarounds mentioned below to overcome this limitation: 1. Go ahead with automatic setup through internal flow template. Once the run starts, pause it, display fluid domain and manually change/assign inlet outlets. 2. Create a fluid body manually instead of with the Create Solution button, and you can now pick as many inlet/outlets as you want with the setup tool.
- Skewness in ANSYS Meshing
