On some newer hardware, using the default MPI (IBMMPII), while exiting a Fluent session the following error message may appear: * hwloc has encountered what looks like an error from the operating system. * * object (Socket cpuset 0xff00ffff) intersection without inclusion! * Error occurred in topology.c line ### * Please report this error message to the hwloc user’s mailing list, * along with any relevant topology information from your platform.
April 5, 2023 at 2:33 pm
FAQParticipantThis message is from a hardware locality library used by IBM MPI. Using the following environment setting will not show this message (or you can use Intel MPI): HWLOC_HIDE_ERRORS=1
- How to avoid the error message “ANSYS Workbench found an error in the value you entered.”
