April 5, 2023 at 2:33 pm
FAQParticipantCFD-Post was modified in version 18.0 to avoid loading some Fluent variables from .dat files, including yplus, as they were not guaranteed to be correct. This is documented in the CFD Post help version 18.2 under “7.15.8. Fluent Files”. The recommended way to view such variables now is to explicitly export them to a .cdat file instead or to post-process in Fluent.
- Skewness in ANSYS Meshing
