April 5, 2023 at 2:32 pm
FAQParticipantIt is necessary to write the case file every time the mesh changes. This is especially true for dynamic mesh or mesh adaption cases. It order to visualize the results correct, it is necessary to bring in these individual case files into CFD post. Keywords: Dynamic mesh, mesh adaption, visualize results
- Skewness in ANSYS Meshing
