General
General
How do you calculate the mass flow across only part of a plane in Fluent?
    • FAQFAQ
      Participant
      The Iso clip function can clip the existing plane to the dimensions you need. Start by making a plane. Go to Postprocessing –> Surface –> Plane. Then, use Surface –> Isoclip to clip that plane. Then resulting entity can be used to calculate the reduced mass flow.
