Tagged: 18.2, fluent, fluid dynamic, fluid-dynamics, General - FLUENT, meshing, parallel
April 5, 2023 at 2:32 pm
FAQParticipantHypermesh may create a single interior zone ID between the multiple fluid regions. This can cause problems with Fluent, and may corrupt the case. If you read the mesh into Fluent Meshing and then immediately switch to Fluent solver (use the icon) the interior is split as intended.
- Skewness in ANSYS Meshing
