April 5, 2023 at 2:32 pm
FAQParticipantThese steps work for v18.x also. 1. First Install the ARC Master Service (if not done already): %AWP_ROOT190%RSMARCtoolswinx64installservice.cmd -arcmaster 2. Add a queue ‘NewRsmQ’ to localhost (current machine): %AWP_ROOT190%RSMARCbinArcConfig queue add NewRsmQ 3. Assign the queue to current machine(let’s say RSMserver): %AWP_ROOT190%RSMARCbinArcConfig queue modify NewRsmQ -m RSMserver if there is problem in using hostname (probably due to alphnumeric name), use IP address of the machine.
