April 5, 2023 at 2:32 pm
FAQParticipantIt appears that this is a problem that only occurs with KDE. It occurs when Qt is installed on the machine and the QT_PLUGIN_PATH is set globally. If this is the problem, it can be resolved by clearing the QT_PLUGIN_PATH variable in the terminal before starting Savant. Something like this should work: > unset QT_PLUGIN_PATH > ./path/to/installation/isavant
- How to avoid the error message “ANSYS Workbench found an error in the value you entered.”
