Tagged: 16.2, mechanical, static, structural-and-thermal, structural-mechanics
March 17, 2023 at 1:12 pm
Solution
ParticipantPlease refer to the attachments to access the Solution.
1. 2041052.pdf
2. Inertia Relief in ANSYS Mechanical (v1_1 FINAL).pdf
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
- ANSYS Mechanical: Fatigue Crack Growth Analysis using SMART Crack Growth
