March 17, 2023 at 1:11 pm
SolutionParticipantPlease refer to the attachments to access the video recording of the webinar and the slides used for the presentation.
1. 2058242.mp4
2. 2058242.pdf
3. 2058242.zip
- What is the cause of the following ANSYS Mechanical error? “The normal of target element 19817570 is not consistent with the normal of target element 19817571 in real set 171. Please use the ENORM command to correct it.”
