Are there examples to understand procedure to Frictional heating prediction simulation between rotating or sliding bodies using coupled Thermal-Structural coupled field elements ?
March 17, 2023 at 1:11 pm
SolutionParticipantRefer two examples in attachment.
3. 2058246.zip
- What is the cause of the following ANSYS Mechanical error? “The normal of target element 19817570 is not consistent with the normal of target element 19817571 in real set 171. Please use the ENORM command to correct it.”
