Licensing
Licensing
How to solve “Session ID not found” error when using Elastic Licensing with Ansys Electronics Desktop ?
    • SolutionSolution
      Participant
      The exact error that you will see in a popup when opening the project or in the ansyscl log is: Failover feature ‘FEATURE_NAME’ specified in license preferences is not available. Unknown LaaS data error: LaaS returned error (318) – Session ID Not Found. In order to solve this issue, please replace existing ansyscl.exe file C:Program FilesAnsysEMAnsysEM20.2Win64licensingclientwinx64 by the one available in the attached zip file. Please note that the ansyscl.exe to be replaced resides under one of the AnsysEMAnsysEM20.2 sub-directories not to be confused with the one that resides under the AnsysEMShared Files sub-directories. This problem has been resolved in 2021 R1.
      1. 2063906.zip
