General
General
How do I display temperature gradient?
    • SolutionSolution
      Participant
      To display gradients, it is needed to keep the temporary solver memory from being freed. This can be done using the following steps: 1.In TUI, use the following command: solve set expert Type yes to the question “Keep temporary solver memory from being freed?” Use default options for other questions. 2.Run the calculation for one iteration 3.In the GUI, go to DisplayContours panel and do the following: -In the Contours of dropdown menu, select Derivatives -Select the temperature gradient direction: dT-dX or dT-dY or dT-dZ -Select the surface you want to display -Click Display
      1. 2041605.pdf
