General
General
How do I use a turbulence model and the non-Newtonian model at the same time?
    • SolutionSolution
      Participant
      Run the TUI command below to use a non-Newtonian model while also using a turbulence model at the same time (i.e. use the non-Newtonian power law with the Carreau model, Cross model, or Herschel-Bulkley model): /define/models/viscous/turbulence-expert turb-non-newtonian? yes
      1. 2041613.pdf
