Is it possible to specify Job Priority prior to submitting a job to the Remote Solution Manager RSM?
March 17, 2023 at 9:01 amFAQParticipant
It is not currently possible to specify Job Priority before submit. We are considering such a feature for a future enhancement. There is however an “Alpha” feature that sorts the array of Queues based on alphabetical order, then runs jobs accordingly Example : Create 3 queues with alphabetical names as follows A_HighPriorityQueue B_NormalPriorityQueue – Jobs in this queue will not run until A_HighPriorityQueue has 0 jobs. C_LowPriorityQueue – Jobs in this queue will not run until A_HighPriorityQueue has 0 jobs AND B_NormalPriorityQueue has 0 jobs. No other configuration changes are required.
- Q: How do I set the license server from my client machine?
- Failover feature ‘Discovery – Level 1’ is not available
- How do I configure RSM to send a solve to a remote machine (no scheduler)?
