March 17, 2023 at 9:01 am
FAQParticipantThe ANSYS associative Creo plug-in does not require Java. Whether Creo itself depends upon JRE or not, it should be determined by the PTC support Team.
- How to avoid the error message “ANSYS Workbench found an error in the value you entered.”
