March 17, 2023 at 9:01 am
FAQParticipantSometimes if you are working with different number of screens it may happen that your WB session would be opened on a screen which does not exists. This can happen on Windows running machines. To see UI please: 1) Click on the application in the toolbar to make it active. 2) Press Windows Key + Shift + Left Arrow (or Right Arrow) at the same time. That should refocus the application onto your monitor.
- How to avoid the error message “ANSYS Workbench found an error in the value you entered.”
