Ansys DMP on single linux node throws error “execution daemon on host didn’t accept task” this happens for versions 18.1 & above, where as works good for below versions.
March 17, 2023 at 9:00 am
FAQParticipantThe full error would be similar to error: executing task of job 207139 failed: execution daemon on host “aci101.cae.abc.local” didn’t accept task* This is a know issue of a Job scheduling application. This can be solved after changing the variable Control slaves to “TRUE” in the Parallel Environment
