Some odd behaviors are found in 2021 R1 RSM, such as: RSM_HPC_JOBTYPE is set to NoUsed for Mechanical jobs Always delete the staging directory whether “Keep job files in staging directory when job is complete” is enabled or not. Customized Mechanical_ANSYSJob.xml for additional file types to upload and download no longer works.
March 17, 2023 at 9:00 am
FAQParticipantCaused by new RSM C++ API in 2021 R1, should be fixed in 2021 R2. Temporary workaround, set environment variable USE_OLD_RSM_API=1 on client machine, reopen Workbench to submit RSM jobs.
