When launching AnsysEDT in Linux through ETX with french.kbf the launch fails. Error seen: X Error of failed request: BadAccess (attempt to access private resource denied) Major opcode of failed request: 100 (X_ChangeKeyboardMapping)
March 17, 2023 at 9:00 am
FAQParticipant“MainWin needs to call the function XChangeKeyboardMapping” Please have the user try: Under Xconfig (Start/All Programs/OpenText Exceed xx/Exceed Tools/Xconfig) – Mouse Keyboard and Other Input Devices – enable “Allow X Clients to Modify Keyboard Mapping” – Validate and Apply changes
