How to get the values of maximum and minimum for X, Y and Z deformation at a time in one row for remote point?
Tagged: 18.2, General, mechanical, static, structural-and-thermal, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantOne can use the User Defined Result with the expression as UVECTORS.
- What is the cause of the following ANSYS Mechanical error? “The normal of target element 19817570 is not consistent with the normal of target element 19817571 in real set 171. Please use the ENORM command to correct it.”
