I’m analysing surfaces in Mechanical that are coming from Spaceclaim. The mass stated value under Properties in the Geometry in Mechanical do not match the Force Reactions on the supports which are induced by Gravity. Do you know why?
Tagged: 18.2, mechanical, static, structural-and-thermal, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantIn Spaceclaim, multiple surfaces, each with a different thickness, can be combined into one surface by using the Stitch command. When this surface is taken into Mechanical, it gets assigned a Face Thickness object per each different thickness present on this surface. The mass property calculation only takes one of these thicknesses into consideration, not all, and so does not provide an accurate mass value.
- What is the cause of the following ANSYS Mechanical error? “The normal of target element 19817570 is not consistent with the normal of target element 19817571 in real set 171. Please use the ENORM command to correct it.”
