March 17, 2023 at 9:00 am
FAQParticipantThe number of integration points for SOLSH190 can be modified using the SECDATA and SECTYPE commands. You can associate a single-layered SOLSH190 element with a shell section. The SECDATA command requires you to specify a thickness. However, the specified thickness is not used for element calculations.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can you identify the element types used by Mechanical?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- How to change begin node and element number for meshing in Workbench Mechanical?
- What is the difference between shell 63 and shell 181?
