Tagged: 16, cfx, fluid-dynamics, Reacting Flows, Species/Reactions
March 17, 2023 at 8:59 am
FAQParticipant•Please start the calculation with the option Output Control -> Results -> Extra Output Variables List •Choose one variable for every Particle group you defined. •Please choose any variable but Volume Fraction. This option activates an internal hook to write the mass flow variable of the particle tracks into the result file. •You can evaluate the mass flow of the particles within your domain similar to the Eulerian phase variables. •In ANSYS CFX please do the following (assuming HC Fuel as particle material name): •Generate an Expression CharMassflowCalc = HC Fuel.Mass Flow * HC Fuel.Char.Mass Fraction •Generate a variable referencing the Expression: Char Mass flow = CharMassflowCalc •Create a plane where you want to calculate the massflow •Bound the plane if necessary (Plane definition -> Geometry tab -> Plane Bounds) •You can set the center of the bounding box if the plane is set by three points •The first point specifies the center. •Sum up the variable Char Mass flow over the plane: sum(Char Mass flow)@plane 1
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- How do I use the Flamelet Generated Model?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How can volume fraction be plotted in a species transport simulation?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
