Created 2D axy symmetric mesh in ICEM CFD and while importing the same in Fluent 2D, error comes as ‘Error at host: Build Grid: Aborted due to critical error. Error at Node 0: Build Grid: Aborted due to critical error. Error: Build Grid: Aborted due to critical error.’
March 17, 2023 at 8:59 amFAQParticipant
For axysymmetric mesh, Fluent has few conditions which are given below axis of rotation should be x-axis cartesian coordinates used in the geometry and y = 0 is the axis line.
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
- Left-handed faces troubleshooting
