Tagged: 2019 R1, fluent, fluid-dynamics, General - FLUENT, solver
March 17, 2023 at 8:58 am
FAQParticipantUnfortunately, there is no information in the User Guide and the Quick Search functionality in Fluent cannot find a relevant command for Courant number modification. However, the Courant number can be adjusted in TUI: You can adjust the Courant number in Fluent TUI via /solve/set/p-v-controls 200 0.75 0.75, where the first number is representative of the Courant number.
- Skewness in ANSYS Meshing
