General
General
Error: “ST_Create_Store: out of memory” in out file.
    • FAQFAQ
      Participant
      Solution: a.This error arises because of the system configuration. b.This error also arises when the problem is more complex geometry and complex physics like reacting flows, multiphase, CHT etc c.For e.g. in case of heat transfer when the user tries to solve convection then the simulation will work fine but if radiation is also involved then this error arises. d.Hence it is recommended to use high end configuration system
