March 17, 2023 at 8:58 am
FAQParticipantFor batch runs if we need to setup a monitor through the TUI. How can we do that? You can use, use the following TUI to set up a surface monitor which will produce a hardcopy of the graphics window every 20 iterations: /solve/monitors/surfaces/set-monitor mon-name Integral domain-name density 1 () yes 6 yes yes The sequence can vary for different monitor type. But all monitor types can be found under: /solve/monitors/surfaces/set-monitor
- Skewness in ANSYS Meshing
