Error: The mesh translation to fluent failed due to non-conformal, duplicate, or degenerate mesh elements.
March 17, 2023 at 8:58 am
FAQParticipantPlease make sure that you do not have any overlapping bodies in mesh. If the mesh is overlapping in any region, it will give this error. Please make sure you have used sharetopology options correctly in the geometry cell to avoid any overlapping regions in mesh. “
- Skewness in ANSYS Meshing
