March 17, 2023 at 8:58 am
FAQParticipantThis is a setting in the SCDM options. From fFiles, select SpaceClaim options. Then go to File Options >Workbench and check the Named Selections box. Make sure to set the appropriate prefix or to empty the Named Selections Key to import all named entities from your CAD file. All the imported named selections are listed in the “Group” tab.
- Skewness in ANSYS Meshing
