March 17, 2023 at 8:58 am
FAQParticipantIn the Graphics performance options group in the Popular screen in SpaceClaim Options, select a higher number Rendering quality. You can choose any number between 1 and 10, where 1 is the lowest rendering quality and 10 is the highest, but be aware that a higher setting may impact performance. Click the Recalculate Rendering button to force recalculation of all surface and line rendering.
- Skewness in ANSYS Meshing
