March 17, 2023 at 8:58 am
FAQParticipantTo select multiple faces, you might have hold the Ctrl key. If you pull when holding the Ctrl key, it copies the faces. Try the following: 1) Hold the Ctrl key to make a copy of a face as you drag. 2) Hold the Ctrl key to select multiple faces, and then release the Ctrl key before using the Pull or Move tools.
- Skewness in ANSYS Meshing
