General
General
I can no longer see the Keyframe panel. Where did it go?
    • FAQFAQ
      Participant
      The Keyframe panel can disappear with the actions. 1. Undock the Keyframe panel 2. Close the Keyframe panel 3. Close EnSight 4. When EnSight is launched again, the Keyframe panel doesn’t show up when you click on the Keyframe button. Starting EnSight with -no_prefs will fix the issue.
