Tagged: 16, Coating Simulation, fluid-dynamics, General, polyflow
March 17, 2023 at 8:58 amFAQParticipant
When defining a coating simulation, a conflict of boundary conditions may potentially develop at the contact point between the free surface and the subsequent moving solid boundary. In steady flow, the free surface assumes a vanishing normal velocity component which may be in conflict with the non-vanishing tangential velocity component applied on the moving solid boundary. A possible remedy consists of replacing the non-vanishing velocity condition on the moving solid boundary by a slipping condition with a high coefficient in the slipping law and the required tangential velocity.
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
- Left-handed faces troubleshooting
