March 17, 2023 at 8:58 am
FAQ
ParticipantDoes it differ on a Linux/Unix machine or on a PC? Solution: For running in menu mode on Linux/Unix and PC, the command is: % polydata -MENUS For running in menu mode from a console file (e.g. file.cons), the command is: on Linux/Unix: % polydata -MENUS < file.cons on PC: X:> polydata -MENUSFLINP < file.cons
- Skewness in ANSYS Meshing
