March 17, 2023 at 8:58 am
FAQParticipantThis solution gives details on ansys turbo tools associated with specific license . Blade modeler license : Blade modeller license consist of 11) Bladegen : Specific blade design tools for turbo machinery components such as radial impeller , axial impeller , deswirl vane and so on . We can design from scratch . 2) Blade editor : Add on tools in Design modeller which has similar feature to bladegen tool and we can also create blade from scratch and parameterize the blade angles and thickness . Additional structural parts can be added such as fillets , hub solid and shroud parts . 3) Vista 1D tools such as Vista AFD(Axial fan design) , Vista CCD(Centrifugal compressor design), Vista CPD(Centrifugal pump design) , Vista RTD (Radial turbine design) These are 1D design tools : based on eulers equation and with inputs of operating conditions (RPM , Flow rate, pressure rise)and some geometry limits , it gives us preliminary impeller design . Which can be further taken to bladegen or bladeeditor . Kindly connect with ansys support team for further details into capabilities .
- Skewness in ANSYS Meshing
