I have several Fluent UDFs loaded that apply properties of Cp, density and viscosity to my materials. When I initialize the case, however, there is an immediate crash. What could the problem be?
Tagged: 19, fluent, fluid-dynamics, Journaling, scripting, Scripting/Journaling/UDF, Species/Reactions, udf
March 17, 2023 at 6:12 am
FAQParticipantThere are a number of reasons for the crash. When initialization occurs, variables are evaluated, so this is where problems with UDFs can sometimes make an early appearance. The possibilities are: 1. The routine was interpreted, and the interpretation cannot be processed by Fluent because the UDF is too complex. If this is the case, compiling the routine should eliminate the problem. 2. An inappropriate UDF was used to define the property. Some properties, like Specific Heat, have their own unique DEFINE routine. If Specific heat is defined with DEFINE_PROPERTY rather than DEFINE_SPECIFIC_HEAT, Fluent will crash.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How can volume fraction be plotted in a species transport simulation?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
