January 25, 2023 at 7:34 am
FAQ
ParticipantStart with a steady state thermal electric system and add ‘antype,trans’ in a commands object inserted into the steady state environment branch. As a reminder, for transient thermal-electric analysis, just be sure that the specific heat and the density are specified and eventually electric permittivity for insulators.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
