January 25, 2023 at 7:34 am
FAQParticipantOne may use “Elastic Foundation Stiffness” (EFS) or “Elastic Support” provided in Mechanical To apply Elastic Support, right-mouse-click the analysis branch from tree outline, say “Static Structural Analysis”, and then choose “Insert”, and choose “Elastic Support”. In the details, scope to the area you want to apply Elastic Support and specify a value for foundation stiffness.
- What is the cause of the following ANSYS Mechanical error? “The normal of target element 19817570 is not consistent with the normal of target element 19817571 in real set 171. Please use the ENORM command to correct it.”
