Question: Why in SpaceClaim options >> Customize >> “Ribbon tabs” I cannot not see the box for Mesh? I have downloaded and installed standalone SpaceClaim Direct Modeler package, I also have the right licenses.
- > Customize >> “Ribbon tabs” I cannot not see the box for Mesh? I have downloaded and installed standalone SpaceClaim Direct Modeler package, I also have the right licenses." target="_blank" rel="nofollow" title="LinkedIn">
- > Customize >> “Ribbon tabs” I cannot not see the box for Mesh? I have downloaded and installed standalone SpaceClaim Direct Modeler package, I also have the right licenses." target="_blank" rel="nofollow" title="whatsapp">
- > Customize >> “Ribbon tabs” I cannot not see the box for Mesh? I have downloaded and installed standalone SpaceClaim Direct Modeler package, I also have the right licenses." target="_blank" rel="nofollow" title="reddit">
- > Customize >> “Ribbon tabs” I cannot not see the box for Mesh? I have downloaded and installed standalone SpaceClaim Direct Modeler package, I also have the right licenses." target="_blank" rel="nofollow" title="facebook">
January 25, 2023 at 7:28 am
FAQParticipantAnswer: SpaceClaim Direct Modeler standalone installation does not contain the meshing tools. ANSYS Structures or ANSYS FLUIDS package need to be installed in order to use SpaceClaim meshing.
- How to avoid the error message “ANSYS Workbench found an error in the value you entered.”
